NMEA Data Sources for QTVLM
- Campion
il y a 11 mois 2 semaines #1976
par Campion
NMEA Data Sources for QTVLM a été créé par Campion
Hi All,
I'm looking for a device I can plug into my NMEA backbone, which will act as a data server to send out data I can pickup on QTVLM on my Windows laptop. Does anyone have a recommendation, or advice on how they get compatible NMEA data sent wirelessly to their laptop based QTVLM installation
I have all B&G sensor equipment onboard, and a B&G Vulcan plotter. I have already bought an Antisense W2K NMEA data logger to perform this function, but none of the data formats it uses seem compatible with QTVLM
Any help would be greatly appreciated
Best
Ray
Best
Ray
il y a 11 mois 2 semaines #1981
Réponse de maitai sur le sujet NMEA Data Sources for QTVLM
Hi Ray,
You need something that will convert NMEA 2000 to NMEA 0183, for instance an Actisense NGW1 (for USB connection) or W2K1 (for WIFI)
- srosset@gmail.com
il y a 2 semaines 3 jours #2479
par srosset@gmail.com
Réponse de srosset@gmail.com sur le sujet NMEA Data Sources for QTVLM
Is it still the case as of may 2024 that qtvlm does not support NMEA 2000? I'm not able to find these details in the documentation.
il y a 2 semaines 3 jours #2480
Yes, that is still the case. You need a converter.
- srosset@gmail.com
il y a 2 semaines 3 jours #2487
Thanks a lot. Is there a list of supported or recommended devices to convert?
For example, Actisense Gateway NGW-1, Actisense NGX-1, NMEA-0183 GATEWAY YDNG-03, NMEA-2000 USB GATEWAY YDNU-02, IKONVERT – NMEA 2000 TO USB CONVERTER, etc.
il y a 2 semaines 3 jours #2489
What I can say is that many people are using Actisense converters (one is for WIFI, the other for a serial connection).
Temps de génération de la page : 0.182 secondes
