Companion app on Paly Store
- alemeni
il y a 1 an 2 mois #1764
par alemeni
Companion app on Paly Store a été créé par alemeni
Hi, I’m tryin to install the companion app o my Suunto 7 Android Wear smatwatch, but on th Google Play Store the intall button in’t opertive, how I can do?
Best Regards…
Best Regards…
il y a 1 an 2 mois #1765
Réponse de maitai sur le sujet Companion app on Paly Store
Suunto watches are normally supported. What version of Android Wear is it running ?
Best regards,
Best regards,
- alemeni
il y a 1 an 2 mois #1772
par alemeni
Réponse de alemeni sur le sujet Companion app on Paly Store
Hi Philippe,
I installed the Companion app on my watch and upgraded software on both PC (Panasonic CF-19 with Windows 7 Pro) and Mac (MacBook Pro with macOS Catalina). Briefly linked with CF-19, but software on PC crashed (same ip and port) but not able to connect on Mac and iPad (also installed the app on iPad).
Any suggestion?
Thank you in advance...
Any suggestion?
il y a 1 an 2 mois - il y a 1 an 2 mois #1777
HI, you are connected via WIFI on a TCP port ? With windows 7 bluetooth is not possible anyway.
It is possible that Windows 7 is not compatible with this, I have nothing to test that.
You have to have NMEA reception on qtVlm side (or in simulation mode). Which MacOS version on the Mac ? Your Android device with Companion should be able to connect to it all the same.
Edit: Sorry you mentioned Catalina for the MacOS version.
- alemeni
il y a 1 an 2 mois #1779
par alemeni
Hi Philippe,
Yes, connection via Wifi on TCP port (the one suggested), no bluetooth.
Yes, have NMEA reception (Green and COG and SOG displays active on Server Mac - PC)
MacOS version is Catalina 10.15.7
Will try with a Win10 laptop where we just installed latest version of qtVlm and let you know.....
- alemeni
il y a 1 an 2 mois #1780
par alemeni
News...
Now it seems to work with Macbook and qtVlm running in simulation mode, only issue is that the watch disconnects from the router...
Will try again this evening with another router....
Temps de génération de la page : 0.189 secondes
