qtVlm 5.10.7 not working on raspberry pi
  • tdml02r
4 years 8 months ago #1117 by tdml02r
trying to run qtVlm 5.10.7 on raspberry pi but getting the following error:
      ./qtVlm
     Aborted
i have tried to install  libxcb-xinerama0 but it is already the latest version (1.14-3)
any ideas  what's wrong?
thanks
Tom
  • maitai
  • Away
  • Administrator
  • Administrator
4 years 8 months ago #1118 by maitai
Replied by maitai on topic qtVlm 5.10.7 not working on raspberry pi
First of all we are now running 5.10.9-p1, please update.
Also have a look at documentation page 9.
--Philippe.
4 years 8 months ago #1119 by oxygen77
Replied by oxygen77 on topic qtVlm 5.10.7 not working on raspberry pi
Also, if updating is not enough, launch qtVlm from command line after inputing this:
Code:
export QT_DEBUG_PLUGINS=1
And put the output here
  • tdml02r
4 years 8 months ago #1120 by tdml02r
Replied by tdml02r on topic qtVlm 5.10.7 not working on raspberry pi
thank you for the fast responses.
upgraded to 5.10.9-p1 and tried everything on page 9 of the manual : still same issue.
debug output:
QFactoryLoader::QFactoryLoader() checking directory path "/home/pi/Downloads/qtVlm/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqlinuxfb.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqlinuxfb.so, metadata=
"IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
"MetaData": {
"Keys": [
"linuxfb"
"archreq": 0,
"className": "QLinuxFbIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("linuxfb")
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqminimal.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqminimal.so, metadata=
"MetaData": {
"Keys": [
"minimal"
"archreq": 0,
"className": "QMinimalIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqoffscreen.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqoffscreen.so, metadata=
"MetaData": {
"Keys": [
"offscreen"
"archreq": 0,
"className": "QOffscreenIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqxcb.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqxcb.so, metadata=
"MetaData": {
"Keys": [
"xcb"
"archreq": 0,
"className": "QXcbIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("xcb")
Cannot load library /home/pi/Downloads/qtVlm/platforms/libqxcb.so: (libxcb-util.so.0: cannot open shared object file: No such file or directory)
QLibraryPrivate::loadPlugin failed on "/home/pi/Downloads/qtVlm/platforms/libqxcb.so" : "Cannot load library /home/pi/Downloads/qtVlm/platforms/libqxcb.so: (libxcb-util.so.0: cannot open shared object file: No such file or directory)"
Aborted
Thanks
Tom
4 years 8 months ago #1121 by oxygen77
I guess that you are on a recent version of raspbian ?
Can you try :
- go in: /usr/lib/arm-linux-gnueabihf
- do: ln -s libxcb-util.so.1 libxcb-util.so.0
Launch again qtvlm
  • tdml02r
4 years 8 months ago #1122 by tdml02r
Yes I’m using the latest version (bullseye)
That worked, thanks very much
