MacOS and 5.10.12
  • zerobeat
4 years 5 months ago #1263 by zerobeat
MacOS and 5.10.12 was created by zerobeat
Hello Philippe,
My Macbook with MacOS Catalina refuses to run version 5.10.12 and provides the following message:
Dyld Error Message:
Library not loaded: @rpath/QtSvg.framework/Versions/5/QtSvg
Referenced from: /Applications/qtVlm/qtVlm.app/Contents/MacOS/qtVlm
Reason: Incompatible library version: qtVlm requires version 5.15.0 or later, but QtSvg provides version 5.13.0
Termination Reason:    DYLD, [0x3] Wrong version
Hopefully this helps to find a solution, and thanks for all your good work,
Regards, Ruud
4 years 4 months ago #1280 by maitai
Replied by maitai on topic MacOS and 5.10.12
Hi Ruud,
I have no explanation. This package runs on many macos machine and no one has reported any issue like that. Maybe you have an old Qt version installed elsewhere and in the path ?
Anyway a new version is due today so let's hope that will automagically fix it.
  • zerobeat
4 years 4 months ago #1281 by zerobeat
Replied by zerobeat on topic MacOS and 5.10.12
Hello Philippe,
The issue was solved after the first patch of 5.10.12. Thanks for all your efforts.
Ruud
