Pathway routing
  • zerobeat
4 years 1 day ago #1425 by zerobeat
Pathway routing was created by zerobeat
Hello Philippe and others,
The ‘append POIs’ function in Pathways makes life so much easier. Thank you for that. There is a small issue that I run into however. When I choose ‘create a routing for this pathway’, the starting point is always the position of the boat. No matter the position of the ‘Routing from boat’ switch. I found no way to start from the first POI of the pathway. Regards, Ruud
4 years 18 hours ago #1426 by maitai
Replied by maitai on topic Pathway routing
The settings on the pathway (start from boat/from first POI) has precedence over the one in routing. So you need to change that in the pathway itself.
--Philippe.
  • zerobeat
4 years 16 hours ago #1427 by zerobeat
Replied by zerobeat on topic Pathway routing
Thanks for the quick reply Philippe, I obviously missed that one. All clear now...
Regards, Ruud
