qtvlm stability
- bluecolumbia
3 years 4 months ago #1837
by bluecolumbia
Replied by bluecolumbia on topic qtvlm stability
the problem occurred again last night - the boat is in a slip, so it is generally in the same location.
while the chart display was not responsive i opened the marks management and attempted to center on a mark... the marks management dialogue closed as expected but the chart display did not update.
i emailed my ini fle.
thank you for taking a look at this, qtvlm is a great program, and very useful to me
...bluecolumbia
...bluecolumbia
3 years 4 months ago #1841
Replied by maitai on topic qtvlm stability
Can you please confirm if you set "keep boat at same position" or not (even if the boat is not moving) ?
Thanks;
Thanks;
- bluecolumbia
3 years 4 months ago #1843
by bluecolumbia
that option was not set, the option to center on the boat while zooming was set…
…bluecolumbia
…bluecolumbia
3 years 4 months ago #1850
Any chance the last version (5.11.2-p1) fixes your issue ?
- bluecolumbia
3 years 4 months ago #1851
by bluecolumbia
so far i have not experienced any more crashes, i'll let you know if it re-occurs. thank you
i think i may have found a bug, though... the route logbook awa and aws are always zero (while the other numbers appear to be accurate). are you seeing this also?
...bluecolumbia
...bluecolumbia
3 years 4 months ago #1852
No problem here with this. Is it an imported or frozen route ?
