Cannot run qtVLM under new MacOS Catalina
- emanahov
6 years 10 months ago #80
by emanahov
Cannot run qtVLM under new MacOS Catalina was created by emanahov
I had the older version of qtVLM and tried to install the newest one. I downloaded it, then copied it into my Documents folder and then executed it.
I choose the language and then I get this message:
Unable to write in qtVlm folder
/private/var/folders/hy/pc3m07s112j6qj223f6vtblr0000gn/T/AppTranslocation/29F8D6AC-E246-45DD-8394-99608879E587/d/testWrite2.txt
Please change the folder permissions or
try to reinstall qtVlm elsewhere
I tried copying the qtvlm folder into many places but I continue to get this message.
Unfortunately when I try to change the folder permissions to Write even with Admin privileges I get a message from OS that this folder is a system folder and it's only read only and it's permissions cannot be changed.
Thanks
Eugeni
Thanks
Eugeni
- Thank you received: 35
6 years 10 months ago - 6 years 10 months ago #81
Replied by maitai on topic Cannot run qtVLM under new MacOS Catalina
Hi Eugeni,
You are not the first one reporting this... Apple did a very fine job indeed
For the time being what has worked for others:
Re-download qtVlm from our site, I just updated it with the same version signed a bit differently which may suit Apple better.
If it still refuses to work, try to launch it from Finder (find qtVlm.app, right-click->run)
And if that fails too, again from Finder right click on qtVlm.app, open in a terminal (last command), and type:
sudo xattr -rc .
(note the point at the end)
Hope that will fix it...
sudo xattr -rc .
Last edit: 6 years 10 months ago by maitai.
- emanahov
6 years 10 months ago #82
by emanahov
Replied by emanahov on topic Cannot run qtVLM under new MacOS Catalina
Dear Philippe,
Thanks for your help
Only the last option did work.
Eugeni
Eugeni
