grib correction
  • el guayacan IV
3 years 1 month ago #2082 by el guayacan IV
grib correction was created by el guayacan IV
it seems that it is possible to switch from one grib file to another smoothly (grib configuration / corrections), but I'm unable to use this functionality; can someone explain?
I found nothing in the documentation nor in the forum.
Thanks,
Pierre.
  • maitai
  • Away
  • Administrator
  • Administrator
3 years 1 month ago #2083 by maitai
Replied by maitai on topic grib correction
There is no "smooth transition" between gribs, qtVlm always uses the best grib available (best resolution) and then when the grib is exhausted either spatially or temporally it switches to the next best grib.
The option you are seeing is for using wind data from instruments and smoothly tend towards grib data when doing routing or routes.
  • el guayacan IV
3 years 1 month ago #2084 by el guayacan IV
Replied by el guayacan IV on topic grib correction
Ok, thanks for your quick answer, clear!!
Smooth transition between gribs could be a nice feature... :-))
Pierre.
Time to create page: 0.114 seconds
