qtVlm 5.12.2 not working on Raspberry Pi4
- jm.joubert@yahoo.fr
2 years 9 months ago #2246
by jm.joubert@yahoo.fr
qtVlm 5.12.2 not working on Raspberry Pi4 was created by jm.joubert@yahoo.fr
I tried to install qtVlm on Rasperry Pi4 Mod.B 64 bits. I tried it both on Raspbian and Debian OS. Each time I could not open qtVlm. I click on the exe file and nothing happens !?
Any idea to fix this problem ?
Thank you for your help
Regards
Regards
2 years 9 months ago #2247
Replied by oxygen77 on topic qtVlm 5.12.2 not working on Raspberry Pi4
Was it working before ? or is it a first install ?
Did you look in this thread: www.meltemus.com/index.php/en/forum/qtvl...ll-to-raspberry-pi-4
Don't hesite to post in above thread if you have further questions
2 years 9 months ago #2249
Replied by jm.joubert@yahoo.fr on topic qtVlm 5.12.2 not working on Raspberry Pi4
Version 5.12.2 never worked. Perhaps I need to try an older one.
2 years 9 months ago #2251
Ok. It is working in current version. Have you tried to follow the info from mentioned thread.
Most of the time it is a missing library that causes this.
2 years 9 months ago #2254
I tried to follow the procedure in mentioned thread.
When I launch qtVlm, I get the pessage :
"error while loadin shared libraries : libpulse-mainloop-glib.so.0: cannot open shared object file: No such file or directory"
So I tried the action below
"sudo apt install libpulse-mainloop-glib0" as described in thread
Then I get the final message :
"E: Impossible de corriger les problèmes, des paquets défectueux sont en mode "garder en l'état""
2 years 9 months ago #2256
Il faudrait dans ce cas plus d'info sur ce qui se passe pendant le "apt install"
pouvez vous refaire:
et nous mettre le resultat complet de la commande?
Code:
