Cannot install qtVlm on macOS Catalina 10.15.2
  • thericksteruk
6 years 8 months ago #117 by thericksteruk
Cannot install qtVlm on macOS Catalina 10.15.2 was created by thericksteruk
hi I am trying to install the new version 5.9.5-p1 and I cannot open the program up after moving the main folder from the dmg to applications, all I get is an error. It says:
"qtVlm" can't be opened because Apple cannot check it for malicious software.
This software needs to be updated. Contact the developer for more information.
I am running macOS Catalina 10.15.2
any help would be gratefully appreciated.
Richard
6 years 8 months ago #118 by maitai
Hi Richard,
Apple did a great job with Catalina indeed...
The solution is to locate qtVlm.app via the finder and to try to run it from there.
If it does not work then again with the finder you should right-click, choose "open a terminal" (the last option), and type:
sudo xattr -rc .
(note the point at the end)
  • thericksteruk
6 years 8 months ago #119 by thericksteruk
Replied by thericksteruk on topic Cannot install qtVlm on macOS Catalina 10.15.2
Hi maitai,
Thanks for that it worked a treat.
Many thanks,
Richard
6 years 8 months ago #120 by labezinchristian
Replied by labezinchristian on topic Cannot install qtVlm on macOS Catalina 10.15.2
Hi Philippe,
The fix worked pretty well ... until I downloaded the -p1 release and now dear Catalina insults me in the following terms :
christian@pc12 ~ % sudo xattr -rc .
Password:
xattr: [Errno 1] Operation not permitted: './.wine/dosdevices/e::'
xattr: No such file: ./.wine/dosdevices/d:
xattr: No such file: ./.wine/dosdevices/d::
Any idea ?
Christian
6 years 8 months ago #121 by maitai
Seems to me that you are not inside qtVlm directory. You should find it with finder and open a terminal from there (right-click, last command).
6 years 8 months ago #122 by labezinchristian
Oops !!!
correct !! so sorry for this unnecessary solicitation
Christian
