TWS & PPC Errors
- MattiMelte
11 months 2 weeks ago #3291
by MattiMelte
Replied by MattiMelte on topic TWS & PPC Errors
so, to summarize:
- STW (which should come from a log sensor right?) is wrong
- TWA is not present at all
All other errors are deriving from these.
Am I correct?
thanks again,
Am I correct?
thanks again,
11 months 2 weeks ago #3292
Replied by maitai on topic TWS & PPC Errors
Yes, exactly.
In fact if you fix STW being completely wrong AND either add TWA or TWD or remove TWS that will be OK.
You can actually do it by filtering the NMEA input in qtVlm: filter out $TIVHW and $TIMWD and that should be more or less OK.
Better fix the source IMO.
- Synapse Navigation
- Senior Member
11 months 2 weeks ago #3293
by Synapse Navigation
=> synapsenavigation.fr
Replied by Synapse Navigation on topic TWS & PPC Errors
What is your speed sensor (brand, ref) ? Can you see it on a display and is it correct ?
Was it ok in the past, or is it a new setup ?
- MattiMelte
11 months 2 weeks ago #3294
by MattiMelte
Hi, my speed sensor is the Garmin Wind Bundle 52. on the dedicated external displays the data seem to be correct.
It is actually a new setup but the electronics which is doing the job is very well established, so i was not expecting issues....
- Senior Member
11 months 2 weeks ago #3295
So if it is correct on the display, it is not your sensor. You said that it is connected to the AIS broadcasting in wifi. The problem is probably there...
We can continue directly by email, as this is no more linked to qtVlm => synapse.navigation@gmail.com
