Boat speed source for TWS calculation
  • MattiMelte
4 months 3 weeks ago #3653 by MattiMelte
Boat speed source for TWS calculation was created by MattiMelte
Hello, I'm struggling to find a way to select which source of boat speed should be used by qtVlm..
I have a log but sometimes get stuck so in that case i want to select GPS.
Is it possible?
Thanks in advance
Matteo
  • Synapse Navigation
  • Senior Member
  • Senior Member
4 months 3 weeks ago #3654 by Synapse Navigation
Replied by Synapse Navigation on topic Boat speed source for TWS calculation
Hello.
The TWS is calculated with the boat speed (BS). If you use the GPS (SOG), you will get the GWS.
=> synapsenavigation.fr
  • MattiMelte
4 months 3 weeks ago #3655 by MattiMelte
Replied by MattiMelte on topic Boat speed source for TWS calculation
Thanks for the feedback first of all.
Does that mean that the TWS will always be calculated using the log, and the GWS will always be calculated using the GPS?
So i need to look at one or the other depending on which source i want to use?
Thanks again
Best
  • Senior Member
  • Senior Member
4 months 3 weeks ago #3656 by Synapse Navigation
This is the definition of these values.
The TWS with the BS (so you are influenced by the current), and the GWS with the SOG (so as you were ‘on the ground’)
I wrote a guide for that if you want to go further (it is in French) :
synapsenavigation.fr/les-guides-synapse-navigation/
  • MattiMelte
4 months 4 days ago #3718 by MattiMelte
I tried this out but it looks like GWS is invalid (see pic attached). But i don't know why since I have a valid SOG and AWS.
