Best Platform
- BlackSwan
4 months 2 weeks ago #3673
by BlackSwan
Best Platform was created by BlackSwan
I want to run QtVLM on my boat. I have a mini-indusrial PC to run it on. I can run windows or any flavour of linux - 32 or 64 bit.
What are the QtVLM developers/serious racers running please? O/S inc version and window manager (if linux).
I'm after reliability - minimum glitches, best on screen performance etc.
I could change the hardware if necessary.
Please please, I'm an experienced IT professional, I don't care whether Linux is better than Windows etc. I just want to copy what the pro's are doing and go sailing....
- Synapse Navigation
- Senior Member
4 months 2 weeks ago #3676
by Synapse Navigation
=> synapsenavigation.fr
Replied by Synapse Navigation on topic Best Platform
Hello
your mini PC will run it very correctly. A large capacity of RAM memory can help if you have many maps. The developers could confirm (I m not).
Your hardware depends also of your power supply possibilities : 12v, 220v on a converter, etc
About the use, have a look at this guy and his screenshots in the videos, he sailed solo around the world with qtVlm : www.youtube.com/@damienjob8257
Another configuration (mine), based on an iPad inside a mini 6,50 where it is not possible to use a PC while sailing : youtube.com/shorts/d0pkImioJ78?si=HpMT0Cele3kMfwNm
The following user(s) said Thank You: BlackSwan
- BlackSwan
4 months 2 weeks ago #3677
by BlackSwan
Replied by BlackSwan on topic Best Platform
Super post, merci !
OpenCPN aussi!
OpenCPN aussi!
- Premium Member
4 months 2 weeks ago #3678
by ozolli
Replied by ozolli on topic Best Platform
On a mini-pc you would want to use linux Debian 13 for maximum stability.
You would need to install some drivers first :
Code:
sudo apt install libxcb-xinput0 libxcb-xinerama0 libmd4c0 libdouble-conversion3
- BlackSwan
4 months 2 weeks ago #3679
by BlackSwan
Ozolli, merci.
This is exactly the information I was looking for.
I have installed Deb `13 but I am going to check those deps/modules.
