QTVLM Android – Cannot set alarms due to overlay window issue
- gmerendino
2 months 1 week ago #3939
by gmerendino
QTVLM Android – Cannot set alarms due to overlay window issue was created by gmerendino
Hi everyone,I'm running into a frustrating issue with the Android version of QTVLM and was hoping someone here might have encountered the same problem or have a workaround.When I try to set an alarm on the Android app, I can't complete the process because an extra selection window pops up and overlays the normal alarm setup interface. This window doesn't appear when using the PC version – everything works fine there. On Android, however, it blocks the view and prevents me from actually selecting or confirming any alarm settings.I've attached a screenshot so you can see exactly what I mean.Has anyone else experienced this? Is there a setting I'm missing, or is this a known bug in the Android build? Any help or suggestions would be greatly appreciated.Thanks in advance!
2 months 1 week ago #3940
Replied by maitai on topic QTVLM Android – Cannot set alarms due to overlay window issue
I confirm the issue, we will fix that asap
The following user(s) said Thank You: gmerendino
- gmerendino
2 months 1 week ago #3941
by gmerendino
Replied by gmerendino on topic QTVLM Android – Cannot set alarms due to overlay window issue
I tried to work around it by manually editing the .ini configuration file and setting both alarmOn=1 and soundOn=1. Unfortunately, even after doing that, no sound is played when the alarm should trigger. So it seems like the issue might go beyond just the UI overlay – the sound generation itself may also be broken on Android.
- gmerendino
2 months 1 week ago #3942
by gmerendino
Since I couldn't set the alarm through the UI, I tried to work around it by manually editing the
and
Code:
.ini
Code:
alarmOn=1
Code:
soundOn=1
2 months 1 week ago #3943
Modifying the ini directly is dangerous and not recommended at all, you risk to loose everything.
Let's wait a couple of hours or so and you will have a fix.
2 months 1 week ago #3944
Which Android version are you running ?
Time to create page: 0.146 seconds
