Pathway menu
- Asolex
1 month 26 minutes ago #4046
by Asolex
Pathway menu was created by Asolex
In the pathway menu when i try to edit a pathway the "information and management" tab won't open? I am using a macbook with het latest qtvlm version. Should I do a fresh install of qtvlm or is it a known bug? On the ipad it works as intended.
Alex
Alex
- Thank you received: 35
4 weeks 2 days ago #4047
Replied by maitai on topic Pathway menu
I cannot reproduce that, what do you mean by "won't open", you cannot go to the tab ?
- Asolex
4 weeks 1 day ago #4048
by Asolex
Replied by Asolex on topic Pathway menu
Yes, when I click on it nothing happens. Something in the alignment seams wrong, when I click on Reverse order the button on Hide pathway line changes. I installed the latest update again but nothing has changed
4 weeks 1 day ago #4049
I cannot reproduce that here. Can you post a screenshot?
Please try the current beta to see if that fixes your issue.
- Asolex
4 weeks 12 hours ago #4050
by Asolex
Using the berta version did not change anything. Using qtvlm in full screen modus did (the green button on the macos screen) . So in full screen modus i can use the pathways menu as intended, when i use a windowed version (althoug screen filling) the menu is off. Something to do with scaling?
4 weeks 5 hours ago #4051
Sorry, I still don't understand your issue, can you please post a screenshot ?
