bluetooth stability
- mawer
6 years 4 months ago #259
by mawer
bluetooth stability was created by mawer
Hallo,
qtvlm runs on a panasonic CF20 (win 10) without any problems; companion runs on a samsung galaxy s7 (android
; to establish the bluetooth connection you have to wait up to several minutes and the connection is not stable at all; running in start mode companion updates the display around once every minute; not useable at all. Any idea whats the problem ?
mawer
mawer
- Thank you received: 35
6 years 4 months ago #260
Replied by maitai on topic bluetooth stability
Do you have this lag issue only in race start mode? For instance map mode is OK?
Normally once the machines are paired the connection is quite fast (not very fast on Windows but in the order of 10 to 20 secs here).
Which version are you using for Companion and qtVlm?
Regards,
Regards,
- mawer
6 years 4 months ago #261
by mawer
Replied by mawer on topic bluetooth stability
qtvlm 5.9.8 ; companion V1.12
Map mode around 10-20 seconds to update the screen; start mode around one minute or even longer..
Regards,
mawer
Regards,
mawer
6 years 4 months ago #262
qtVlm should be 5.9.8-p1, Can you check and eventually update?
Companion version is OK.
Regards,
Regards,
- mawer
6 years 4 months ago #263
by mawer
it is 5.9.8-p1
Regards
mawer
Regards
mawer
6 years 4 months ago #264
OK.
Here no problems with chart mode, it's been a long time I have not checked start line mode in BT, I will tomorrow.
Any chance you can check in WIFI mode?
