Small bug in configuration
il y a 6 ans 2 mois #301 par Sailabout
Small bug in configuration a été créé par Sailabout
As my Android tablet broke down, I reverted to my laptop (with Widows 10) and found that I could not modify individually the settings in "Configuration -> Charts -> Rasters and Vectors -> Customized". The buttonns "Clear all" and "Set all" do work, but I can not select any item individually nor can I move the side slide.
I encounter this problem with version 64 bits 5.9-4 and version 5.9-9-patch1.
The same problem exist on the 32 bits version 5.9-9-path1 installed on a Raspberry Pi 4 with "Buster".
il y a 6 ans 2 mois #302 par maitai
Réponse de maitai sur le sujet Small bug in configuration
You need to change the display category to "Customized" in order to be able to access these fields
il y a 6 ans 2 mois #303 par Sailabout
Réponse de Sailabout sur le sujet Small bug in configuration
Thank you for your quick answer.
Temps de génération de la page : 0.120 secondes
