Editing Pathways
- edmund.davis
il y a 6 ans 3 semaines #398
par edmund.davis
Editing Pathways a été créé par edmund.davis
It would be great to be able to add / edit / rearrange Pathway POIs as a list in the Pathway dialogue. Is that something which could easily be added?
Thanks,
Edmund
Thanks,
Edmund
il y a 6 ans 3 semaines #399
Réponse de maitai sur le sujet Editing Pathways
I am not sure I understand your request, can you elaborate a bit?
Note that you can change the POI order by editing the POI, and you can insert/move/delete new POIs via the contextual menu of the pathway (right-click on PC)
Regards,
Regards,
- edmund.davis
il y a 6 ans 3 semaines #400
par edmund.davis
Réponse de edmund.davis sur le sujet Editing Pathways
Hi Philippe.
As I see it, the current method of assigning pathways to POIs is a bit backwards. For me, it would be better if we started to define a pathway and added a sequence of POIs to the pathway instead of the other way round.
When we're passage planning for a trip or race, we typically create a "pathway" between a list of new or existing POIs (waypoints) so it would be very useful to be able to enter and view POIs directly in a list when defining the pathway. These could then be easily rearraged to change the order or add additional waypoints.
This would be useful both for racing (when courses are announced) or cruising when planning a passage.
Thank you,
Edmund
Thank you,
Edmund
- edmund.davis
il y a 6 ans 3 semaines #402
par edmund.davis
Thanks for following up
The current method seems backwards to me. POIs should be a member of various Pathways, instead of the other way around. Do you see what I mean?
When we're passage planning for a trip, we typically create a "pathway" and then we add a number of new or existing POIs (waypoints) so it would be very useful to be able to enter and view POIs directly in a list when defining the pathway instead of having to assign the Pathway to the POI.
I would like to be able to Edit Pathway and then be able to add a number of POIs to the pathway in a list / sequence - and rearrange them if necessary. And for racing, we would want to be able to add the same POI to the pathway multiple times.
Thanks in advance
Thanks in advance
Temps de génération de la page : 0.122 secondes
