Raspberry Pi: small file missing in 5.9.11?
- Sailabout
il y a 6 ans 3 semaines #404
par Sailabout
Raspberry Pi: small file missing in 5.9.11? a été créé par Sailabout
After unpacking/installing qtVlm 5.9.11 on a Raspberry Pi, I could not put a shortcut on the desktop. The file qtVlm.desktop seems to be missing.
Otherwise, the software works very well. Thank you.
il y a 6 ans 3 semaines #405
Réponse de maitai sur le sujet Raspberry Pi: small file missing in 5.9.11?
: If you want to create a shortcut for qtVlm on Raspberry on the desktop, you can follow
instructions contained in the file instructions_launcher_rpi.txt
- Sailabout
il y a 6 ans 3 semaines #406
par Sailabout
Réponse de Sailabout sur le sujet Raspberry Pi: small file missing in 5.9.11?
I know and I have to edit that qtVlm.desktop file with the path of qtVlm. But hte file is not there . . .
il y a 6 ans 3 semaines #407
I just checked and the file is in the archive qtVlm-5.9.11-rpi.tar.gz, so there is no reason it would be missing for you. Maybe you are trying via a file explorer and the file is hidden? Can you please try with a console?
- Sailabout
il y a 6 ans 3 semaines - il y a 6 ans 3 semaines #408
par Sailabout
Got it., Philippe.
I was confused, the file is there but without visible .desktop extension in the name. I had the full name with extension in a previous version installation, hence my search. . .
Thank you for your help.
Paul
Paul
