Polar file format question
- HeatWave
il y a 5 ans 8 mois #698
par HeatWave
Polar file format question a été créé par HeatWave
Hello, I'm trying to create a polar file for a J/111. The polar file format is simple enough, but it seems to lack the optimum upwind and downwind targets. For example, a few lines from an Expedition polat format (similar to other systems) is:
4 0 0 47 4.6 55 4.8 60 5.1 70 5.35 80 5.7 90 6.2 100 6.38 110 6.11 120 5.76 130 5.22 137 4.4 180 2.28
6 0 0 45 5.6 55 5.9 60 6.1 70 6.35 80 6.6 90 7 100 7.15 110 7 120 6.75 130 6.32 141 5.5 180 3.37
8 0 0 43 6 55 6.95 60 7.2 70 7.35 80 7.6 90 7.8 100 7.92 110 7.94 120 7.75 130 7.43 145 6.75 180 4.47
So at 4 knots TWS, target is 47 degrees and 4.6 knots, at 6 knots target is 45 degrees for 5.6 knots and so on.
But the format you have seems to omit that capability, so that I need a target boat speed for each combination of TWA and TWS. How does qtVLM figure the optimum targets when beating or running?
il y a 5 ans 8 mois #700
Réponse de maitai sur le sujet Polar file format question
qtVlm calculates itself the beating and running angles limits based on the polar values. You can also force it in the boat's settings.
You can see the result of these calculations in boat->Wind Polar Analysis.
-- Philippe
-- Philippe
- HeatWave
il y a 5 ans 8 mois #701
par HeatWave
Réponse de HeatWave sur le sujet Polar file format question
Thank you Philippe...
About forcing, it looks like I can only do that for a single angle for upwind and another for downwind, but this varies with TWS. Is that correct?
il y a 5 ans 8 mois #702
Yes, if you force it that will apply for all TWS
That is why it is much better to let qtVlm calculate it.
