- Remerciements reçus 1
Pivot Point malfunction or misundestood?
- dverona
- Membre junior
il y a 5 ans 7 mois #836
par dverona
Pivot Point malfunction or misundestood? a été créé par dverona
Using the Pivot point function it seems to me that the new isochronses from the position of the Pivot Point are calculated beginning from the original Routing Start Time while I supposed it should be start from the arrival time in the Pivot Point. I noticed this because I had a routing not reaching the target WP, but establishing a Pivot Point the new routing reach the target. This is confirmed as displaying the isochrones for both original and new routing (with Pivot Point), it shows 2 active isochrones: 1 starting from the boat position and an other starting from the Pivot Point. Is this the right behaviour of a routing with Pivot Point ?
il y a 5 ans 7 mois #837
Réponse de maitai sur le sujet Pivot Point malfunction or misundestood?
Thanks for reporting this we will check. Obviously the pivot routing should start at the time/position of the pivot point.
Maybe this bug is triggered because you have checked "Keep starting date" ?
- dverona
- Membre junior
il y a 5 ans 7 mois #838
par dverona
Réponse de dverona sur le sujet Pivot Point malfunction or misundestood?
Yes. I checked "Keep starting date", and I just verified that deselecting this flag the behaviour is right: the pivot routing start at time/position of pivot point.
il y a 5 ans 7 mois #839
OK thanks, I will fix that.
- dverona
- Membre junior
il y a 5 ans 7 mois #840
par dverona
Thanks to you
