Qtvlm stops simulation stating aground. When depth is 25 mts?
- `PCSmith
Auteur du sujet
il y a 4 ans 8 mois #1091
par `PCSmith
Qtvlm stops simulation stating aground. When depth is 25 mts? a été créé par `PCSmith
Hi, I have run many simulations and Qtvlm stops simulation stating aground. When depth is 25 mtrs?
The boats depth is not 25 mtrs?
il y a 4 ans 8 mois - il y a 4 ans 8 mois #1092
Réponse de maitai sur le sujet Qtvlm stops simulation stating aground. When depth is 25 mts?
Which version are you using? The one released today (5.10.9) has many changes concerning depth and simulation mode.
il y a 4 ans 8 mois #1093
What are the values you have set in Charts->Rasters and Vectors for Shallow Contour, Safety Contour, etc ?
- `PCSmith
Auteur du sujet
il y a 4 ans 8 mois #1094
par `PCSmith
Réponse de `PCSmith sur le sujet Qtvlm stops simulation stating aground. When depth is 25 mts?
I have used new version today and also went back to older version.
- `PCSmith
Auteur du sujet
il y a 4 ans 8 mois #1095
par `PCSmith
I changed the depths to around 2 5 and 8 for deep
il y a 4 ans 8 mois #1096
The rule is that whatever has a depth equals or less than shallow contour will be an obstacle and therefore will make simulation to run aground, and whatever is between shallow and safety will only be a danger and will trigger an alarm. Whatever can be rock, wreck, sounding, obstruction, depth area and depth contour.
