Import Export GPX PATWAY
il y a 4 ans 8 mois #1114 par amajori
Import Export GPX PATWAY a été créé par amajori
I saw that it is now possible to export GPX from a Pathway; is it also possible to import GPX to create pathways?
On IOS is it possible to do it from a file manager folder?
Thanks
Antonio
il y a 4 ans 8 mois #1115 par maitai
Réponse de maitai sur le sujet Import Export GPX PATWAY
No you can only export in gpx format. If you want to transfer a pathway from one qtVlm to another you must use the qpar format.
On iOS export will generate a file in the shared folder that you can pick up from there, and if you put a qpar file there you can also import it.
