MacOS and 5.10.12
- zerobeat
il y a 4 ans 4 mois #1263
par zerobeat
MacOS and 5.10.12 a été créé par zerobeat
Hello Philippe,
My Macbook with MacOS Catalina refuses to run version 5.10.12 and provides the following message:
Dyld Error Message:
Library not loaded: @rpath/QtSvg.framework/Versions/5/QtSvg
Referenced from: /Applications/qtVlm/qtVlm.app/Contents/MacOS/qtVlm
Reason: Incompatible library version: qtVlm requires version 5.15.0 or later, but QtSvg provides version 5.13.0
Termination Reason: DYLD, [0x3] Wrong version
Hopefully this helps to find a solution, and thanks for all your good work,
Regards, Ruud
Dyld Error Message:
Regards, Ruud
il y a 4 ans 4 mois #1280
Réponse de maitai sur le sujet MacOS and 5.10.12
Hi Ruud,
I have no explanation. This package runs on many macos machine and no one has reported any issue like that. Maybe you have an old Qt version installed elsewhere and in the path ?
Anyway a new version is due today so let's hope that will automagically fix it.
- zerobeat
il y a 4 ans 4 mois #1281
par zerobeat
Réponse de zerobeat sur le sujet MacOS and 5.10.12
Hello Philippe,
The issue was solved after the first patch of 5.10.12. Thanks for all your efforts.
Ruud
Ruud
