Imported GPX as Route doesn't display Statistics or Histogram data
- MichaelBender
Auteur du sujet
il y a 4 ans 3 mois #1298
par MichaelBender
Imported GPX as Route doesn't display Statistics or Histogram data a été créé par MichaelBender
Hi, I opened this issue to collect a few questions that I have about importing a GPX as a Route on the Mac version of qtVlm. I want to import a GPX file so that I can view it on the chart and analyze the data inside the file (elevation and SOG for example). I import the GPX file using Route -> Import route -> In GC mode. I select my route on the chart and then select Edit route <route name>. I see the Route Settings window and select the Statistics tab but there is no data displayed from my route. I then select the Histograms tab and select SOG but nothing is displayed. Using other programs I have verified that my GPX file contains SOG data.
il y a 4 ans 3 mois #1303
Réponse de maitai sur le sujet Imported GPX as Route doesn't display Statistics or Histogram data
It's not a bug. An imported route is frozen and therefore cannot calculate stats. You can unfreeze it and it will calculate itself based on current grib data, which is maybe not your goal.
- MichaelBender
Auteur du sujet
il y a 4 ans 3 mois - il y a 4 ans 3 mois #1304
par MichaelBender
Réponse de MichaelBender sur le sujet Imported GPX as Route doesn't display Statistics or Histogram data
Is there any way to look at and display the data inside a GPX file (such as SOG) so that I can get a graph of, say, SOG without having any grib data involved? My use case is to view data related to a sail race that is now finished and when I am off the boat.
il y a 4 ans 3 mois #1307
No there is no way in qtVlm
There are plenty of free gpx analyser available on the net.
- MichaelBender
Auteur du sujet
il y a 4 ans 3 mois #1308
par MichaelBender
OK thanks.
