Install to Raspberry PI 4
il y a 3 ans 7 mois #1541 par oxygen77
Réponse de oxygen77 sur le sujet Install to Raspberry PI 4
Could you try installing libmd4c0 ?
il y a 3 ans 7 mois #1542 par Jolie Fleur
Réponse de Jolie Fleur sur le sujet Install to Raspberry PI 4
Hi Oxygen,
Thanks for the help but it doesn't seem to work.
pi@joliefleur:~ $ cd qtVlm
pi@joliefleur:~/qtVlm $ ./qtVlm
./qtVlm: error while loading shared libraries: libmd4c.so.0: cannot open shared object file: No such file or directory
pi@joliefleur:~/qtVlm $ sudo apt install libmd4c0
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
E: Impossible de trouver le paquet libmd4c0
il y a 3 ans 7 mois #1543 par oxygen77
can you then list available package with:
sudo apt list | grep libmd4c
il y a 3 ans 7 mois #1544 par Jolie Fleur
I get :
pi@joliefleur:~/qtVlm $ sudo apt list | grep libmd4c
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
I googled that sentence but didn't find any solution for the apt list command
il y a 3 ans 7 mois #1545 par oxygen77
I guess that after the Warning you get back the prompt ?
The warning is "normal" and is always there in case of the list subcommand.
So this means that this lib is not available in the repository
can you confirm what is telling:
lsb_release -a
and
cat /etc/debian_version
also can you confirm the file name of the .tar.gz you are trying to install ?
il y a 3 ans 7 mois #1546 par Jolie Fleur
Yes
lsb_release -a
pi@joliefleur:~/qtVlm $ lsb_release -a
No LSB modules are available.
Distributor ID:    Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:    10
Codename:    buster
and
pi@joliefleur:~/qtVlm $ cat /etc/debian_version
10.13
qtVlm-5.10.18-rpi32Bullseye.tar.gz
Temps de génération de la page : 0.128 secondes
