Raspberry pi 4 Ubuntu version
- sparticle
- Membre junior
il y a 6 ans 11 mois #46
par sparticle
Raspberry pi 4 Ubuntu version a été créé par sparticle
Hi I have a 4GB Raspberry pi 4 running the latest Ubuntu 18.04.3 Ubuntu Desktop. How can I get your software running on this platform as this will probably be our base platform for building our next gen low power Navigation Computer to be integrated into our boat.
Cheers
Spart
Cheers
Spart
- Remerciements reçus 2
il y a 6 ans 11 mois #51
par oxygen77
Réponse de oxygen77 sur le sujet Raspberry pi 4 Ubuntu version
Have you already tried ? Any error messages ? On our side we usualy have a simple raspbian or openplotter. Never tryed on ubuntu but appart from lib issue it should be working fine
- sparticle
- Membre junior
il y a 6 ans 11 mois #52
par sparticle
Réponse de sparticle sur le sujet Raspberry pi 4 Ubuntu version
Yes it just would not run and complaned about it being in teh wrong format.
I also tried compiling OpenCPN and that worked fine and is running pretty well on Ubuntu. I cannot however get the cart plugins osenc or S63 to work as they only compile as armhf and they are not compatible.
The Pi4 will be the new standard very soon it is simply much more powerful and useful for this job.and Ubuntu is the most widely used Linux desktop environment with the most active development community.
Cheers
Spart
Cheers
Spart
- Remerciements reçus 32
il y a 6 ans 11 mois #53
Réponse de maitai sur le sujet Raspberry pi 4 Ubuntu version
What version did you tried to install? You should be trying the Raspberry build, not the Linux one.
- sparticle
- Membre junior
il y a 6 ans 11 mois #54
par sparticle
Yes tried it. It just complains about no such file. I changed the paths t the correct paths in my case home/ubuntu/Downloads/qtVlm and tried running /home/ubuntu/Downloads/qtVlm/qtVlm also tried changing into qtVlm directory and running ./qtVlm nothing works.
Without a version compiled for the aarch64 Rpi4 platform I suspect it will not work.
I will test on another rpi4 that is running raspbian.
Cheers
Spart
Cheers
Spart
Temps de génération de la page : 0.128 secondes
