Can't add POIs to Pathway
il y a 3 ans 7 mois #1694 par rgatter
Can't add POIs to Pathway a été créé par rgatter
Hi!
I installed version5.11-1 (meltemus) (Jan 17 2023) and can't add POIs to a pathway. There is no dialog entry to select a pathway in the POI dialog
In version 5.10.15 it worked
In version 5.11.1 it doesn't
I had this behaviour an an older version, bur later it worked again
Thx, Robert
il y a 3 ans 7 mois #1695 par maitai
Réponse de maitai sur le sujet Can't add POIs to Pathway
All this has completely changed a couple of versions ago.
POIs can be added/removed/moved etc from the pathway editor directly, please refer to the documentation.
il y a 3 ans 7 mois #1696 par rgatter
Réponse de rgatter sur le sujet Can't add POIs to Pathway
Thank you!
I promise the next time I  read the manual. I didn't expect this change but it is great and makes it easier to create pathways.
Temps de génération de la page : 0.120 secondes
