routings not saved between program starts
- bluecolumbia
il y a 3 ans 4 mois #1813
par bluecolumbia
routings not saved between program starts a été créé par bluecolumbia
using 5.11-1 on windows
i've noticed that all of my routings are lost every time i exit qtvlm. i don't know if this is intentional behavior or a bug, but i would like to be able to save routings.
routes and pathways are saved between program starts as expected, it is only routings that are lost.
thank you...
...bluecolumbia
thank you...
...bluecolumbia
- Remerciements reçus 2
il y a 3 ans 4 mois #1814
par oxygen77
Réponse de oxygen77 sur le sujet routings not saved between program starts
Yes, this is the expected behavior
Routing would take a lot of data to save and would not mean anything without the proper gribs loaded.
What would be your use of restoring routing later?
- bluecolumbia
il y a 3 ans 4 mois #1818
par bluecolumbia
Réponse de bluecolumbia sur le sujet routings not saved between program starts
hi
thank you for your reply.
i think it is important to be able to save routings.
the primary reasons for saving routings are to prevent repetitive tasks for the user, and to be able to compare routings with other routings.
it is not good to find that the routings i have run are gone, and must be regenerated after a windows update restarts my computer, or after i am forced to restart qtvlm because it has become unresponsive. this leads to a lot of repeated tasks for the user. i am asking this question because i find that i am regularly repeating the process of generating the same routing.
thank you...
...bluecolumbia
thank you...
...bluecolumbia
Temps de génération de la page : 0.169 secondes
