Linux: Qt WebEngine resources not found
- Donnybrook
il y a 3 ans 2 mois #2062
par Donnybrook
Linux: Qt WebEngine resources not found a été créé par Donnybrook
Starting with qtVlm 5.11.3 on my LInux laptop (Chromebook, Debian GNU/Linux 11 (bullseye), I get the warnings below and qtVlm screen is blank when it starts (no map, no menu). It also happens with qtVlm 5.11.5. Every version up to qtVlm 5.11.2 P1 works and reinstalling 5.11.2 P1 fixes it.
What's missing?
penguin:~/qtVlm$ ./qtVlm
Starting-up first line
[0716/100703.393568:WARNING:resource_bundle_qt.cpp(115)] locale_file_path.empty() for locale
Qt WebEngine resources not found at //resources. Trying parent directory...
Qt WebEngine resources not found at /. Trying application directory...
Installed Qt WebEngine locales directory not found at location /translations/qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location /home/kylesewing1/qtVlm/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Path override failed for key ui::DIR_LOCALES and path '/home/kylesewing1/.QtWebEngineProcess'
[0716/100703.430360:WARNING:resource_bundle_qt.cpp(115)] locale_file_path.empty() for locale
[0716/100703.443391:WARNING:resource_bundle_qt.cpp(115)] locale_file_path.empty() for locale
What's missing?
- Remerciements reçus 37
il y a 3 ans 2 mois #2063
Réponse de maitai sur le sujet Linux: Qt WebEngine resources not found
Is it an arm-based machine? What tar file did you download from our site ?
- Donnybrook
il y a 3 ans 2 mois #2064
par Donnybrook
Réponse de Donnybrook sur le sujet Linux: Qt WebEngine resources not found
It's Intel (core i3 8th gen). I downloaded 5.11.5 today (qtVlm-5.11.5-64_1.tar.gz). The last version that works is qtVlm-5.11.2-p1-64_1.tar.gz downloaded April 16.
Kyle
Kyle
- Remerciements reçus 2
il y a 3 ans 2 mois #2068
par oxygen77
Réponse de oxygen77 sur le sujet Linux: Qt WebEngine resources not found
Tested today on my linux runing a Ubuntu 20.04
I have the same warnings but qtVlm loads fine anyway.
Can you please try:
- rename/move the ~/.qtVlm folder to something like ~/.qtVlm_sav
- launch qtVlm from scratch
Can you please try:
il y a 3 ans 2 mois #2069
I am sending you an email with the missing translations files.
- Marc S
il y a 1 an 6 mois #2968
par Marc S
Réponse de Marc S sur le sujet Linux: Qt WebEngine resources not found
I have the same problem on an Intel chromebook running Linux Debian GNU/Linux 12 (bookworm)
launching the app results in:
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
When qtVlm launches, the screen display is normal but no keyboard commands or mouse clicks register. How to fix?
