Android Grib opening
  • konradstreit
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 3 ans 1 mois #2074 par konradstreit
Android Grib opening a été créé par konradstreit
I'm trying to open relatively large grib files on my android phone. There appears to be a file size limit, which is fine, however when I select a smaller zone in qtvlm before opening the file, the coordinate range it opens is not the selected area. It tries to open an area south of the selection, for which there is no data.
Can anyone reproduce this error?
il y a 3 ans 1 mois #2077 par maitai
Réponse de maitai sur le sujet Android Grib opening
You are right, there is a small bug that I just fixed, thanks for reporting that.
That will be in the next version, in the mean time you can select a much bigger zone than what you really need and that should be OK.
  • konradstreit
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 3 ans 2 semaines #2093 par konradstreit
Réponse de konradstreit sur le sujet Android Grib opening
Ah brilliant, didn't expect an answer this quickly at all, thanks for fixing it!
