grib correction
- el guayacan IV
il y a 3 ans 1 mois #2082
par el guayacan IV
grib correction a été créé par el guayacan IV
it seems that it is possible to switch from one grib file to another smoothly (grib configuration / corrections), but I'm unable to use this functionality; can someone explain?
I found nothing in the documentation nor in the forum.
Thanks,
Pierre.
Thanks,
Pierre.
- Remerciements reçus 35
il y a 3 ans 1 mois #2083
Réponse de maitai sur le sujet grib correction
There is no "smooth transition" between gribs, qtVlm always uses the best grib available (best resolution) and then when the grib is exhausted either spatially or temporally it switches to the next best grib.
The option you are seeing is for using wind data from instruments and smoothly tend towards grib data when doing routing or routes.
- el guayacan IV
il y a 3 ans 1 mois #2084
par el guayacan IV
Réponse de el guayacan IV sur le sujet grib correction
Ok, thanks for your quick answer, clear!!
Smooth transition between gribs could be a nice feature...
Pierre.
Pierre.
Temps de génération de la page : 0.118 secondes
