buttons in 'boat settings' not properly mapped
- cdocsail
- Membre junior
il y a 2 ans 6 mois #2359
par cdocsail
buttons in 'boat settings' not properly mapped a été créé par cdocsail
from the menu boat-> boat settings
clicking on polar brings up the sails config dialog
clicking on sails configurarions brings up the waves and gusts parameters
clicking on any button on the list brings up the dialog of the button 'below' it.
using qtVLM 5.12-4 using Qt 5.15.16 on an M1 mac running sonoma 14.1
however this menu functions normally on an older macVersion : 5.12-4 (meltemus) (Jan 8 2024)
System osx 10.13
Qt 5.15.16
Memory size: 16,384 Gb
CPUs: 8
Build for: x86_64
Running on: x86_64
1 screen(s), size 1440x900, retina x 2
System osx 10.13
Qt 5.15.16
CPUs: 8
Build for: x86_64
Running on: x86_64
il y a 2 ans 6 mois #2360
Réponse de maitai sur le sujet buttons in 'boat settings' not properly mapped
Probably your pointing device is not compatible. Can you try with a normal mouse to see ?.
- cdocsail
- Membre junior
il y a 2 ans 6 mois #2361
par cdocsail
Réponse de cdocsail sur le sujet buttons in 'boat settings' not properly mapped
this happens with a regular microsoft mouse, a logitech g703 mouse and the native trackpad. It only happens in the dialog that appears when you you select boat>boat settings.
Once you select some button from that dialog (and go to the wrong page) then all the buttonns work correctly.
