Routing through Safety Contour
il y a 2 ans 5 mois #2373 par Sam Graber
Routing through Safety Contour a été créé par Sam Graber
When Creating a Route, qtVlm continues to calculate and plot a course that trangresses my defined Safety contour depth...and even Shallow contour! I can't seem to find a setting in (Alt-R) Options or Advanced Settings that says, "don't create a route that takes the boat into water shoaler than my defined safety contour." Please let me know what I can do to correct, thanks!
il y a 2 ans 5 mois #2374 par maitai
Réponse de maitai sur le sujet Routing through Safety Contour
Hi Sam,
Safety contour is a danger, not an obstacle. Shallow contour is an obstacle and should be avoided by routing. Make sure that
1) Dangers/obstacles by S57 is selected
2) You do have S57 at that place
3) In routing avoid land and barriers is checked.
4) In routing just reset values to default or select automatic setting with quality slider fully to the right
A screenshot might help, as usual
il y a 2 ans 5 mois #2375 par Sam Graber
Réponse de Sam Graber sur le sujet Routing through Safety Contour
1) I couldn't find "Dangers/obstacles by S57" in the Routing options menus, Do you mean activating Configuration/Charts/"Coast lines from vector charts S57/63"?
2) Yep.
3) I'd been assigning 0.10nm to Avoid barriers and coasts, but error messages were flashing and blocking routes from being calculated. So I lowered this to 0.05nm. Do you suggest keeping this at 0.00nm?
4) Yes, I've had the Automatic Parameters selected with the slider all the way to the right for Best accuracy.
Same starting and finish points. Results with your above 4 areas attended to are...
The routing course is no longer going over Shallow Contours! But it is directly passing over 1 obstruction, 1 dangerous wreck and almost directly over 2 ATONs. The routing course is thick red in those places, as if it knows it's crossing a hazard.
I'm curious if users in practice are leveraging qtVlm as an advanced route planning tool, by first receiving its course calculation, before going in and micro-adjusting the qtVlm route, accounting for currents, hazards, traffic separation lanes, etc.
Meanwhile, I understand the difference between dangers (objects <= Safety Contour) and obstacles (objects <= Shallow Contour), but are you writing that we are not able to have qtVlm calculate routing to avoid Safety Contour? That qtVlm routing will only avoid Shallow Contour? That's cool, users can input their Safety to equal their Shallow, I'm just wondering.
Apologies for loading many questions within this one thread. Overall, I'm trying to understand how others are optimizing qtVlm for practical routing, as this is a big big feature of the program.
Sam
il y a 2 ans 5 mois #2376 par maitai
Routing does not avoid wrecks or ATON or buoys etc (because these are just points without geometry)
You want to be able to cross the safety contour otherwise you will never make it to the marina.
il y a 2 ans 5 mois #2377 par Sam Graber
=10.0ptWhich marina? :) I haven't used qtVlm to route in Berthing (usage band) charts near any marina slip or mooring spot because we captains should be actively piloting inshore navigation. The first and the final 15 minutes of passages are usually the most complex. But even if I wanted to route to a marina via qtVlm, consider as noted herein and as seen in the example screenshot   that qtVlm routing doesn't properly account for fairway, narrow channel and traffic separation lane rules. That’s a problem. Meanwhile, I don’t understand what “points without geometry” means but qtVlm routing taking a boat right over ATONs and other real-world obstructions is also impractical. Third, unless I missed something, currents aren’t factored into qtVlm route planning.=10.0ptSo I've been creating routes in qtVlm using terminus points that mark channel entrances, such as lighted bell buoys. My routes cross relatively open waters.=10.0ptWhich is why I do not want my routes to cross the Safety Contour. My primary question for this thread still stands - are we not able to have qtVlm calculate routing to avoid crossing the user-defined Safety Contour?
il y a 2 ans 5 mois #2378 par maitai
Once more:
Routing is not designed for that kind of approach. You use routing when traveling on long distances. Do you really expect the routing to avoid a low here? A route is much better, and in that case a pathway with with a safety check envelope is probably even better, and will account for obstacles that are points.
Wrong. Please read documentation
Wrong. You are indeed missing something. Load a grib with currents or force currents.
Safety contour is not an obstacle. If you want to have a shallow contour at 20m it is your decision.
