Scanning Angle
il y a 2 ans 4 mois #2404 par dverona
Scanning Angle a été créé par dverona
Is it possible to set-up a scanning angle greater than 180°. In my understanding, it is necessary in some routage circumstances: for example from Carloforte to Cagliari.
il y a 2 ans 4 mois #2406 par maitai
Réponse de maitai sur le sujet Scanning Angle
No, the maximum is 180°
For this kind of cases, you should use a "circumvent angle" (see documentation page 220).
For instance, let's say you want to route from Caligliari to Capos Marco (even more difficult), then you should first create a routing to somewhere in the South (you can choose North if you want to turn on the other side) and count roughly the number of isochrons needed. This does not need at all to be precise. He we have roughly 20 isochrons
Then with this info, you can create the final routing, with -90° as a circumvent angle for 20 isochrons (note that in that case you also need to uncheck autozoom so qtVlm "sees" all.
