QTVLM and Raymarine Autopilot
il y a 1 an 1 mois #3155 par scud
Réponse de scud sur le sujet QTVLM and Raymarine Autopilot
photos.app.goo.gl/YZpQXktQioXtwHdPA
Thank you for helping.  Here you can find the screenshots.  If something specific is needed please give directions.  I have no filter on sentences.
I am attaching the NMEA log too.
Fichier attaché :
Nom du fichier : NMEA_in_out.txt
Taille du ficher :21.82 Ko
Fichier attaché :
il y a 1 an 1 mois #3156 par maitai
Réponse de maitai sur le sujet QTVLM and Raymarine Autopilot
You don't want "Retransmit all" since that will retransmit all NMEA data, creating a loop.
In the receiving tab you should leave only the useful serial port (I guess COM2) until it works.
You can also try the option "With NMEA2000 compatible names".
il y a 1 an 1 mois #3161 par scud
Here comes the fuzzy part ...!!!
GARMIN AIS is on COM7
SILVA NEXUS + other senders are on COM1 (baud rate 4800)
qtvlm output is on COM2 to all listeners
Now .... if I check off the 2retransmit all" on my standard horizon DSC radio I don't get the position.
According to the manual it accepts GLL, GGA, RMC and GNS and qtvlm does output RMC with retransmit all either checked or unchecked, but if I uncheck it then the vhf does not receive position.
il y a 1 an 1 mois #3162 par maitai
What exactly is arriving on the various COM ports ? For me you have a mess in the connections and the sentences qtVlm sends for WP never arrive to where they should. The problem is not in qtVlm, I think.
il y a 1 an 1 mois #3163 par scud
You may be right. I did it a while ago. I'll review everything again and freshen it up.
il y a 1 an 1 mois #3164 par scud
In order for me to debug properly it would be helpful a tool to monitor the COM port that qtvlm uses to output its sentences in order to d-check what actually sens out.
Is there any such a tool on Win10?  the COM port being already open I cannot use hyperlink or NMEA Reader or such.
Qtvlm has a specific header maybe?  I thought it was $GPxxx but the I was looking at the AIS talker (wile qtvlm was down) ad i noticed $AIxxx and $GPand $P as well while on that COM only the AIS was sending
Thanks
Temps de génération de la page : 0.128 secondes
