sails file content
- Portoni
il y a 2 ans 5 jours #2673
par Portoni
sails file content a été créé par Portoni
Someone can translate me the content of file sample.saildef in english or italian? Giving maybe an example.. Asym could be for example a code zero or Gennaker?
The content is:
1;GV + Genois
2;GV + Inter
3;1ris + Inter
4;2ris + Foc
5;3ris + Foc
6;GV + Leger
7;GV + Assym
8;GV + Sym
I think GV stand for Grand voile = main sail. Others?
Thank you very much
Roby
The content is:
1;GV + Genois
2;GV + Inter
3;1ris + Inter
4;2ris + Foc
5;3ris + Foc
6;GV + Leger
7;GV + Assym
8;GV + Sym
Thank you very much
Roby
- Remerciements reçus 37
il y a 2 ans 4 jours #2674
Réponse de maitai sur le sujet sails file content
This is just a sample. You can edit it and change all the names, add or remove configurations like Main sail with 3 reef and jib, etc.. Then you use the numbers in the other file according to TWS/TWA
- Membre elite
- Remerciements reçus 1
il y a 1 an 11 mois - il y a 1 an 11 mois #2704
par ourasi
Réponse de ourasi sur le sujet sails file content
Hi Roby,
You can create your sailselect and saildef manually,but you can also use this excel spreadsheet (see attached: polar_master.xlsx - just remove the .txt extension once you downloaded it). This spreadsheet is fully customizable, just make it yours according to your sail set, boat specs... Then it gets very usefull in case you just need to change your saildef ou fine tune your sailselect. 3 main tables you can play with (CODE, HEAD SAILS and MAIN), saildef and sailselect data will adjust automatically. Follow the instructions to create your files and eventually you'll end up with a similar QTVLM sail instrument (see pic attached).
Enjoy!
Enjoy!
