- Remerciements reçus 1
Wind Polar Analysis
- dverona
- Membre junior
il y a 1 an 5 mois #2992
par dverona
Wind Polar Analysis a été créé par dverona
I observed on my installation that using the Wind Polar Analysis the TWA for "best upwing VMG" and "best downwind VMG" are the same. Is it a misconfiguration on my workstation or a little bug ?
Dante
Dante
- NoDoubt5035
- Membre junior
il y a 1 an 3 mois #3097
par NoDoubt5035
Réponse de NoDoubt5035 sur le sujet Wind Polar Analysis
I am not sure what datapoints are the same. The input for the Wind Polar analysis is the polar that you uploaded. If speed data points are similar that means these are the same in the polar. Best to double check your file if you expect different results.
Ludwig
Ludwig
- dverona
- Membre junior
il y a 1 an 3 mois #3098
par dverona
Réponse de dverona sur le sujet Wind Polar Analysis
It happens always for every uploaded polars for every TWS. It seems that in WInd Polar Analysy the twa for best upwind vmg is displayed also in the field of the best downwind vmg, because they are always the same.
- NoDoubt5035
- Membre junior
il y a 1 an 3 mois #3100
par NoDoubt5035
- dverona
- Membre junior
il y a 1 an 3 mois #3105
par dverona
You understood correctly, but my screenshot is different from yours: I have always the same value of TWA for upwind and downwind.. I will install the last patch, I am running with the 5.12-15 version and I will check again.
- NoDoubt5035
- Membre junior
il y a 1 an 3 mois #3106
par NoDoubt5035
Ok curious whether it works
Temps de génération de la page : 0.160 secondes
