How to turn GSHSS off?
il y a 1 an 3 semaines #3230 par Wesa
How to turn GSHSS off? a été créé par Wesa
Hi! qtVlm documentation mentions on page 154:
Shapefiles can be used as barriers. For instance, if you do not want to use the imprecise gshhs coast lines from gshhs, you can specify in Charts configuration that you want to use coasts lines from vector charts, load a shapefile and indicate that you want to use it as a barrier. qtVlm will then stop using gshhs and will use the shapefile and eventually the vector charts if any for all coast’s detection functions.
I am able to load a shapefile via Charts > Shapefile and SHOM an mark it as a barrier, but I can't seem to figure out how to disable the GSHHS from qtVlm > Configuration. Any suggestions?
Help would be much appreciated!
Wesa :)
il y a 1 an 3 semaines #3231 par maitai
Réponse de maitai sur le sujet How to turn GSHSS off?
In vector charts parameters activate "Coast lines by Vector charts" and make sure you don't have any S57 where the barrier is
il y a 1 an 3 semaines #3232 par Wesa
Réponse de Wesa sur le sujet How to turn GSHSS off?
Thank you for the quick reply! The option "Coast lines from vector charts" seems to be grayed out. I haven't added any S57 files, working with a completely new install.
il y a 1 an 3 semaines #3233 par maitai
Just add one free chart from the US, using our NOAA chart downloader
il y a 1 an 3 semaines #3234 par Wesa
That did the trick! Many thanks!!!
Temps de génération de la page : 0.151 secondes
