qtVlm.desktop file doesn't exist for desktop launcher
il y a 11 mois 2 semaines #3272 par gni
Installed qtVLM raspberry Pi 5" bookworm
in the installation guide i try to follow the instructions to add desktop launcher
But the file qtVlm,desktop doesn't exist in the directory.
Any suggestions ?
Thx Gerard
File "instructions launcher raspberry Pi
ENGLISH:
Modify QtVlm.sh with an editor to replace the path with the path where qtVlm is installed (1 place)
modify qtVlm.desktop with an editor to replace the path where qtVlm is installed (2 places).
run the following command:
cp qtVlm.desktop ~/.local/share/applications
il y a 11 mois 2 semaines #3278 par cameronag
Réponse de cameronag sur le sujet qtVlm.desktop file doesn't exist for desktop launcher
You will have to create the qtVlm file yourself using  a text editor such as "nano".
The file should contain text something like this:
[Desktop Entry]
Name=QtVlm
Path=/home/agc/Downloads/QtVlm/qtVlm/  << path to where your qtVlm executable is located
Exec=/home/agc/Downloads/QtVlm/qtVlm/qtVlm  << your qtVlm executable
Icon=/home/agc/Downloads/QtVlm/qtVlm/icon/qtVlm.ico  << location of a suitable icon
Type=Application
Terminal=false
Categories=Accessories;
Then make the text file executable using the chmod command
chmod +x <<your .desktop file>>
or right-click in File Manager, or on the desktop, select Properties, Permissions and check "Allow executing file as a program".
I had exactly the same problem just a few hours ago in Linux Mint!
Les utilisateur(s) suivant ont remercié: gni
il y a 11 mois 2 semaines #3279 par oxygen77
Réponse de oxygen77 sur le sujet qtVlm.desktop file doesn't exist for desktop launcher
For rapsberry pi5 in the tar.gz you should find 3 files :
- qtVlm.sh
- instructions_for_launcher_rpi.txt
- qtVlm.desktop
I've just double checked and latest version (qtVlm-5.12.17-p3-rpi5_64.tar.gz) is ok
Anyway this is not bulletproof and the way to document the file might differ from one linux to another one
