- Remerciements reçus 1
Tool that creates a polar from QTVLM VDR data or QTVLM Traces
Auteur du sujet
- Membre elite
il y a 8 mois 3 semaines #3393
par ourasi
Réponse de ourasi sur le sujet Tool that creates a polar from QTVLM VDR data or QTVLM Traces
En fait le PPC va t'afficher 80% la nuit si tu as une efficacité de 80% pour lanuit, par contre le jour il t affiche toujours 100% quelque soit tes efficacités au près ou au portant. Ce qui porte a confusion c'est qu'il le fait dans un cas mais pas dans l'autre...d'où mon questionnement existentiel
De toute façon, tant que les efficacités sont prises en compte dans le routage, c'est le plus important.
Merci pour la réponse.
- Synapse Navigation
- Membre senior
il y a 8 mois 3 semaines #3394
par Synapse Navigation
=> synapsenavigation.fr
Réponse de Synapse Navigation sur le sujet Tool that creates a polar from QTVLM VDR data or QTVLM Traces
Hello
Very interesting tool (that could be implemented in qtVlm? this is a subliminal message to Philippe ...
I don't have the details of the computing (you mention average on another forum), but in my opinion, it would be important to:
- select the best speed among similar ones (for each TWA and TWS of course)
- remove the highest or lowest ones is they are totaly different from the others. It could be due to external factors like a 'surf'
- add a visual to see where are the breaks in the curve and to correct them manually (a break can be explained at the sail change as from genois to genaker for example, but out of these changes, the graphics are generally smooth)
- it could be interesting to add an information (I don't know how, this is my Santa Claus letter !) as the sails used for the record. Then, the tool would do the polar AND the sailselect. Or it can do different polars files based on the sails used. This function is generally missing in most of the tools.
Do you know patricktiercelin.wixsite.com/logiciels-t...in1/logiciel-polauto it is a tool to build a polar based on the NMEA record. Some idea could be shared.
I would be pleased to help if I can.
Temps de génération de la page : 0.124 secondes
