qtVlm fails to launch with missing shared libraries error
il y a 7 mois 2 semaines #3426 par Marc S
I periodically get this error when trying to launch qtVlm on Linux: error while loading shared libraries: libx86emu.so.2: cannot open shared object file: No such file or directory
It doesn't happen always.  For a while I thought by launching after a reboot and before launching any other apps I could avoid the problem, but that's not the case. The odd thing is that it only happens intermittently. Any suggestions?
il y a 7 mois 2 semaines #3427 par oxygen77
This error is usual in case of a bad installation / missing libs. What is strange is that it is not hapening each time.
It would help to determine more precisely in which conditions it happens.
Also we could try to understand by looking where are the libs by doing this when qtVlm can be launched and in the case of issues
find /usr/lib /usr/local/lib -name "libx86emu*"
this gives on my side:
/usr/lib/x86_64-linux-gnu/libx86emu.so.2
/usr/lib/x86_64-linux-gnu/libx86emu.so.2.0
I extract the folder containing the lib (/usr/lib/x86_64-linux-gnu/) and do:
ls -l /usr/lib/x86_64-linux-gnu/libx86emu*
which gives me:
lrwxrwxrwx 1 root root 16 août 22 2019 /usr/lib/x86_64-linux-gnu/libx86emu.so.2 -> libx86emu.so.2.0
-rw-r--r-- 1 root root 153696 août 22 2019 /usr/lib/x86_64-linux-gnu/libx86emu.so.2.0
report us the result of find and ls in both cases
il y a 7 mois 2 semaines #3429 par Marc S
Thank you for your response. I should have mentioned in my original post that the error happens on a Chromebook.
Running the suggested search returns no matches. The nearest thing is the directory drwxr-xr-x 1 root root 61908 Dec 25 12:46 x86_64-linux-gnu which does not include any similarly-named libraries. It makes me wonder how I'm able to run qtVlm ever. Is this a dependency only for newer versions of the software?
il y a 7 mois 2 semaines #3431 par Marc S
Those libraries are not present on the Chromebook I'm using. I made a more complete reply yesterday with details, but it's not showing up.
il y a 7 mois 1 semaine #3432 par oxygen77
We are not familiar with chromebooks deployment. Usually this library can be installed using the package manager.
We are also looking to ways to remove this dependency and I'm not sure if it will possible and we will do it.
