SOG/COG not working
  • AlessandroLandi84
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 5 mois 1 semaine #3539 par AlessandroLandi84
SOG/COG not working a été créé par AlessandroLandi84
Hello
I've the complete qtvlm 5.12.2101 build 1 version on ios 18.5 qt 5.12.19 arm64 chip, ipad pro 12.9 2018(3rd gen),
position always enabled with high precision on.
only internal GPS no other sources active, ais through internet off, all gribs off, class 40 polars 100%, compass sensor on, real mode, no vlm:
with NMEA on, SOG stays still on -1.9, COG swings between correct values and 359° every few seconds, no raw NMEA data is shown(gps position is correct and shown correctly, track is correct, routage works)
PLEASE HELP
il y a 5 mois 1 semaine #3540 par maitai
Réponse de maitai sur le sujet SOG/COG not working
Can you test with another application, like Apple map or google map ?
  • AlessandroLandi84
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 5 mois 1 semaine #3541 par AlessandroLandi84
Réponse de AlessandroLandi84 sur le sujet SOG/COG not working
GPS works properly in any other app -even in qtvlm, but speed stays still on -1,9 knots, and angle swings to -359 every few seconds
il y a 5 mois 1 semaine #3542 par maitai
That is strange.. Please check in NMEA settings that you didn't check "All sources", it should not be activated.
  • AlessandroLandi84
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 5 mois 1 semaine #3543 par AlessandroLandi84
as said, it is not checked
SOG is -1,9, COG swings to 359° every few seconds
il y a 5 mois 1 semaine #3544 par maitai
Can you please double check? I cannot imagine another reason. It is a switch in the internal GPS parameters.
Just tested here with a non moving iPhone, no problems.
