- zerobeat
il y a 1 jour 23 heures #4093
par zerobeat
Réponse de zerobeat sur le sujet Beta versions
Thanks for yet another great update in 5.12.28 beta 14. I particularly like the new rendering of isolines. A small remark. In the arrow density setting there are now only four fairly large steps. Different from the smoother way that arrow size and isoline size use. It would be nice to have the same level of control over arrow density also.
Regards, Ruud
Regards, Ruud
- Remerciements reçus 2
il y a 1 jour 23 heures #4094
par oxygen77
Réponse de oxygen77 sur le sujet Beta versions
Yes! This is also new and we forgot to talk about it. It is a fully new way to display arrows. They are now anchored to point on the chart and panning / zooming will not change their position, I found it simpler now to follow wind condition as arrows will not turn of grow just by moving the chart.. For now it has been designed with a limited number of step. I want to evaluate if on the long term it is an issue or not. This slider will also manage the spacing of wind roses.
Other sliders are managing width of lignes which could stay with small spaces as the opacity
- zerobeat
il y a 1 jour 22 heures #4095
par zerobeat
Thanks for your explanation. I still find it difficult to understand what the differences and advantages of the new method are, but hopefully experience will tell...
- Membre elite
- Remerciements reçus 1
il y a 1 jour 16 heures - il y a 1 jour 16 heures #4096
par ourasi
Retours sur l'évaluation de la 5.12.28-beta14:
- Ici, je n'ai que 4 niveaux de densité des barbules. Pourvoir jouer avec ce param permet parfois de mieux visualiser le mouvement global des masses d'air...
- Problèmes GRIB pression: les H/L ne s'affichent plus. Ça s'affiche avec le même grib dans la verison courante. Merci pour les nouveaux isobares, ça c'est un vrai +
- Sinon, voir ci-joint, message d'erreur routage vide (Depart = arrivée)
A+
A+
il y a 1 jour 11 heures #4097
par oxygen77
Pour les 4 pas, cf plus haut en anglais. C'est une conséquence d'une amélioration de l'affichage des fleches qui sont maintenant ancrée sur la carte et donc ne bouge plus à chaque zoom ou déplacement de carte. Je vais revoir, je dois pouvoir faire autrement.
Pour H/L je suis preneur du grib sur support@meltemus.com, j'ai changé la logique d'affichage car il y en avait beaucoup trop d'afficher. Mais c'est peut etre un peu trop agressif selon les cas et regime de pression.
- Remerciements reçus 32
il y a 10 heures 9 minutes #4101
Beta15 available/dispo
