Boat speed source for TWS calculation
il y a 4 mois 2 semaines #3653 par MattiMelte
Boat speed source for TWS calculation a été créé par MattiMelte
Hello, I'm struggling to find a way to select which source of boat speed should be used by qtVlm..
I have a log but sometimes get stuck so in that case i want to select GPS.
Is it possible?
Thanks in advance
Matteo
il y a 4 mois 2 semaines #3654 par Synapse Navigation
Réponse de Synapse Navigation sur le sujet Boat speed source for TWS calculation
Hello.
The TWS is calculated with the boat speed (BS). If you use the GPS (SOG), you will get the GWS.
=> synapsenavigation.fr
il y a 4 mois 2 semaines #3655 par MattiMelte
Réponse de MattiMelte sur le sujet Boat speed source for TWS calculation
Thanks for the feedback first of all.
Does that mean that the TWS will always be calculated using the log, and the GWS will always be calculated using the GPS?
So i need to look at one or the other depending on which source i want to use?
Thanks again
Best
il y a 4 mois 2 semaines #3656 par Synapse Navigation
This is the definition of these values.
The TWS with the BS (so you are influenced by the current), and the GWS with the SOG (so as you were ‘on the ground’)
I wrote a guide for that if you want to go further (it is in French) :
synapsenavigation.fr/les-guides-synapse-navigation/
il y a 3 mois 3 semaines #3718 par MattiMelte
I tried this out but it looks like GWS is invalid (see pic attached). But i don't know why since I have a valid SOG and AWS.
