QTVLM Android – Cannot set alarms due to overlay window issue
il y a 1 mois 4 semaines #3939 par gmerendino
Hi everyone,I'm running into a frustrating issue with the Android version of QTVLM and was hoping someone here might have encountered the same problem or have a workaround.When I try to set an alarm on the Android app, I can't complete the process because an extra selection window pops up and overlays the normal alarm setup interface. This window doesn't appear when using the PC version – everything works fine there. On Android, however, it blocks the view and prevents me from actually selecting or confirming any alarm settings.I've attached a screenshot so you can see exactly what I mean.Has anyone else experienced this? Is there a setting I'm missing, or is this a known bug in the Android build? Any help or suggestions would be greatly appreciated.Thanks in advance!
il y a 1 mois 4 semaines #3940 par maitai
I confirm the issue, we will fix that asap
Les utilisateur(s) suivant ont remercié: gmerendino
il y a 1 mois 4 semaines #3941 par gmerendino
I tried to work around it by manually editing the .ini configuration file and setting both alarmOn=1 and soundOn=1. Unfortunately, even after doing that, no sound is played when the alarm should trigger. So it seems like the issue might go beyond just the UI overlay – the sound generation itself may also be broken on Android.
il y a 1 mois 4 semaines #3942 par gmerendino
Since I couldn't set the alarm through the UI, I tried to work around it by manually editing the
Code:
.ini
Code:
alarmOn=1
 and
Code:
soundOn=1
il y a 1 mois 4 semaines #3943 par maitai
Modifying the ini directly is dangerous and not recommended at all, you risk to loose everything.
Let's wait a couple of hours or so and you will have a fix.
il y a 1 mois 4 semaines #3944 par maitai
Which Android version are you running ?
