NMEA2000 Battery status display?
- jeroenb
il y a 3 semaines 3 jours #4043
par jeroenb
NMEA2000 Battery status display? a été créé par jeroenb
Now that there is NMEA2000 connectivity, it would be really handy if I could monitor my boat battery status. Would it be possible to add instruments to monitor PGN 127508 (Battery Status) and 127506 (DC Detailed Status)?
Thanks for considering,
Jeroen
Jeroen
- Remerciements reçus 32
il y a 3 semaines 3 jours #4044
Réponse de maitai sur le sujet NMEA2000 Battery status display?
Hi, I think it is already there, in a separate dashboard
See Menu->View->NMEA2000 engine and system dashboard
- jeroenb
il y a 3 semaines 3 jours #4045
par jeroenb
Réponse de jeroenb sur le sujet NMEA2000 Battery status display?
Nice, totally missed this menu entry. I'll try next time on the boat. Thanks!
- jeroenb
il y a 2 semaines 4 jours #4052
par jeroenb
At the boat now. My engine and system dashboard remains empty. It seems the NMEA2000 data as sent by the Actisense WGX-1 is not understood. It has an option for ‘N2K ASCII’, N2K Binary’ and ‘NGT Binary’. When I do ‘show raw nmea data’, then it show some garbage output, but none of the instruments show any data. The manual does say that NGT-1 data should be inderstood with USB, but I can’t do USB, since qtvlm is running on android. Any chance any of the WGX-1 protocols could be supported on tcp?
il y a 2 semaines 4 jours #4053
It seems that we forgot to implement this with TCP/UDP, but hopefully it will be quite easy to fix.
One thing you can do that will help:
Set the WGX-1 to N2K ASCII and output over TCP, point qtVlm at it, open Show raw NMEA data, you should now see readable text lines instead of garbage. Copy 20-30 lines (ideally with the engine running so 127489/127488 are there) and send them to us (support@meltemus.com). Nothing will display yet but that will help us to understand what to expect.
- jeroenb
il y a 2 semaines 4 jours - il y a 2 semaines 4 jours #4054
par jeroenb
It's weird: when doing as you suggest (N2K ASCII), the raw data display doesn't show anything. But, when I connect to the same port on my laptop (using `nc 192.168.4.1 2001`), I do get data. I attached a file. No engine data though, because my engine doesn't have any sensors. But there should be battery data.
Cheers,
Jeroen
Cheers,
Jeroen
