Pathway menu
il y a 3 semaines 1 jour #4046 par Asolex
Pathway menu a été créé par Asolex
In the pathway menu when i try to edit a pathway the "information and management" tab won't open? I am using a macbook with het latest qtvlm version. Should I do a fresh install of qtvlm or is it a known bug? On the ipad it works as intended.
Alex
il y a 3 semaines 9 heures #4047 par maitai
Réponse de maitai sur le sujet Pathway menu
I cannot reproduce that, what do you mean by "won't open", you cannot go to the tab ?
il y a 2 semaines 6 jours #4048 par Asolex
Réponse de Asolex sur le sujet Pathway menu
Yes, when I click on it nothing happens. Something in the alignment seams wrong, when I click on Reverse order the button on Hide pathway line changes. I installed the latest update again but nothing has changed
il y a 2 semaines 6 jours #4049 par maitai
I cannot reproduce that here. Can you post a screenshot?
Please try the current beta to see if that fixes your issue.
il y a 2 semaines 5 jours #4050 par Asolex
Using the berta version did not change anything. Using qtvlm in full screen modus did (the green button on the macos screen) . So in full screen modus i can use the pathways menu as intended, when i use a windowed version (althoug screen filling) the menu is off. Something to do with scaling?
il y a 2 semaines 5 jours #4051 par maitai
Sorry, I still don't understand your issue, can you please post a screenshot ?
