Android tablet - Windows 10 connection
- PedroBM35
il y a 5 ans 11 mois - il y a 5 ans 11 mois #456
par PedroBM35
Android tablet - Windows 10 connection a été créé par PedroBM35
Doing some home test, I’m having problems with TCP connection of the full Companion version installed in a Samsung tablet Android to a Qtvlm installed in a Windows 10.
Already checked:
- IP Companion: Router gateway IP 192.168.1.1
- Android and Windows port: 5010
- Selected simulation mode (can”t receive NMEA data at home)
Looking forward for some help.
Thanks in advance.
Pedro
Already checked:
Thanks in advance.
Pedro
- Remerciements reçus 32
il y a 5 ans 11 mois #457
Réponse de maitai sur le sujet Android tablet - Windows 10 connection
Is 192.168.1.1 the address of the Windows machine? Is the android device connected on the same network and can you ping it from the PC? What is the Android device IP address?
Regards,
Regards,
- PedroBM35
il y a 5 ans 11 mois #458
par PedroBM35
Réponse de PedroBM35 sur le sujet Android tablet - Windows 10 connection
Many thanks for prompt feedback!
After Companion IP correction (I was using router gateway IP instead of qtvlm PC IP) and ping confirmation, the connection was successful.
Unfortunately I couldn’t reconnect again although the IP, ping and simulation mode is apparently correct.
What can be wrong?
What can be wrong?
il y a 5 ans 11 mois #459
Hi again,
I don't know, do you have data in qtVlm instruments on the PC, and do you have a grib loaded covering boat's position?
- PedroBM35
il y a 5 ans 11 mois - il y a 5 ans 11 mois #462
par PedroBM35
Hi Philippe,
I have updated qtvlm to 5.9.12 and checked again using a GRIB for the area and the instruments receiving data in simulation mode but the problem persist.
Is there any firewall setup that should be checked?
Regards,
Pedro
Regards,
Pedro
il y a 5 ans 11 mois #463
Please double check your IP adresses and that the PC can see the Android device via ping.
Any antivirus running blocking port 5010 ? You can try to change the port number to for instance 10110.
Temps de génération de la page : 0.162 secondes
