5.9-10 macOS 10.15.5 MBP 2020 preference mishap
  • MichelleWhy
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 6 ans 1 mois #349 par MichelleWhy
5.9-10 macOS 10.15.5 MBP 2020 preference mishap a été créé par MichelleWhy
Hi guys,
upgraded to 5.9-10 on a brand new MBP 13" 2020 and having issues to edit preferences.
Example: I want to edit Network sources. To activate the field, I have two click somewhere in between "start NMEA" on top of it. And this happens to every field I wanna edit or check, sliders etc. When I click on Local Sources, nothing happens. When I click on top of it, I get into the menu.
Not a big deal when you know about it, but you should know it.
Cheers
Stefanie
il y a 6 ans 1 mois #350 par maitai
Réponse de maitai sur le sujet 5.9-10 macOS 10.15.5 MBP 2020 preference mishap
Hi Stefanie,
This is strange. Is it the tab label that is not responding or somehow the switches (king of checkboxes) ? If it is the tabs do you have the same behavior in let's say charts settings?
Cheers,
  • MichelleWhy
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 6 ans 1 mois #351 par MichelleWhy
Réponse de MichelleWhy sur le sujet 5.9-10 macOS 10.15.5 MBP 2020 preference mishap
Hi Philippe,
it's on all tabs in preferences from General to Advanced. The strange thing here is, when I click on every tab starting from left to right, it seems ok. When I go back clicking on every tab item, I need to click above the tab as if the click point moved one line above.
Inside those tabs it's in Boat and Instruments and NMEA connections only for every item.
Cheers,
Stefanie
il y a 6 ans 1 mois #375 par maitai
Hi Stefanie,
It took us some time to fix that one (difficult to reproduce), but we believe it is fixed in 5.9.11, can you please confirm it?
  • MichelleWhy
  • Auteur du sujet
  • Hors Ligne
  • Nouveau membre
  • Nouveau membre
il y a 6 ans 1 mois #376 par MichelleWhy
Hi Philippe,
installed yesterday. No change, means the error is still there. Sorry.
Stefanie
il y a 6 ans 1 mois #377 par maitai
Hmmm that sounds quite weird, are you sure qtVlm->help->about says 5.9.11 ?
Temps de génération de la page : 0.148 secondes
